shpunt
Местный
2.0 - 245 сил - очень интересный вариант.
Начало прожаж - начало 2015
Вот ещё у него будет:
Key technology features include:
Active Grille Shutters: Available on select models to help counter air resistance
Adaptive cruise control and collision warning with brake support: Uses radar to detect moving vehicles directly ahead and change the cruising speed if necessary
Adaptive steering technology: Most advanced steering system ever from Ford makes Edge easier to maneuver and more fun to drive by optimizing steering response in all conditions
Air curtain: Creates a curtain of air alongside the vehicle using smart duct work, improving aerodynamics at high speed
Auto Start-Stop technology: Turns the engine off to save fuel when the vehicle is stopped, then restarts the engine in milliseconds when the brake is released; specially tuned for Edge
Blind Spot Information System: BLIS® uses radar to trigger a warning when another motorist is in the driver's blind spot
Cameras: New 180-degree front camera with washer featured for first time on a Ford vehicle; standard rear camera
Cross-traffic alert: Uses radar to help alert drivers to oncoming traffic when backing out of a parking space
Enhanced active park assist: Builds on Ford parallel parking technology and includes a system to guide the vehicle into a perpendicular parking space. The system can also steer the vehicle into and out of a parallel parking space
Forward and reverse sensing systems: The systems provide audible alerts designed to help drivers avoid obstacles when parking
Hands-free liftgate: Allows customer to move leg below center of the rear bumper to unlock and raise liftgate
Heated and cooled front seats, heated rear seats, heated steering wheel: Amenities make occupants more comfortable, and every drive more enjoyable
Lane-keeping system: Alerts driver to steer the vehicle back into its lane if the vehicle is allowed to drift
Side parking sensors: uses sensors and algorithms that measure speed and steering wheel angle to warn drivers of obstacles on either side of the vehicle during parking or low-speed maneuvers
SYNC® with MyFord Touch®: Becoming available for more trim levels; standard on Edge Sport and Titanium series
Safety technologies available on the new Edge include:
Active glove box knee airbag: Advanced new design uses glove box front to cushion the knees of the front seat passenger in a crash. A pliable, injection-molded plastic bladder is sandwiched between the inner and outer glove box door panels. On impact, a small inflator fills the bladder, extending the glove box outer door panel toward the passenger's legs
AdvanceTrac® with Roll Stability Control™: Uses sensors to measure the roll rate of the vehicle and predict its roll angle. Based on this information and measurements from other vehicle dynamics sensors, the system can adjust engine torque and brake pressure at all four wheels to help the driver maintain control of the vehicle
Curve Control: Uses the same sensors as Roll Stability Control to detect and measure roll rate, yaw rate, lateral acceleration, wheel speed and steering wheel angle to help drivers follow their intended path by slowing the vehicle more efficiently while maneuvering a curve
Inflatable rear safety belts: An advanced restraint system that combines attributes of safety belt and airbag technologies. It is designed to reduce head, neck and chest injuries for rear seat passengers in frontal crashes by distributing crash force energy across five times more of an occupant's torso than a traditional safety belt. Inflatable belts are available for second-row outboard seating positions
