RNS 315 вопрос-ответ
rekram
19 Сен 2014
спб
гольф 5
Zehn, автоскан тут не радует:( кроме ошибки замка в двери водителя ничего нет
Tuesday,01,October,2013,20:23:22:40973
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ1KZ8W054598 License Plate:
Mileage: 113320km-70413mi Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56
VIN: WVWZZZ1KZ8W054598 Mileage: 113320km/70413miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 GG
Component: SIMOS71 1.6l 2V 1025
Revision: --H04--- Serial number: VWXBZ0G0651781
Coding: 0004071
Shop #: WSC 01279 785 00200
VCID: 6ADB242A45DFE44E2A7-803F
No fault code found.
Readiness: 0010 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8DA57E6EDDB1E6AD9-806A
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 79F90B6630795FD6D3D-802C
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007320642
Coding: 118F8F27000F1500471400001400000000097F073200010C000000000000
Shop #: WSC 01287 785 00200
VCID: 71E93346680917966BD-8024
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 030707 021 0501
Coding: 00040853
Shop #: WSC 01287
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 39 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1BHUWB
Coding: 0013113
Shop #: WSC 01269 785 00200
VCID: 3D71DF7664D1A3F6BF5-8068
Subsystem 1 - Serial number: 6332MSME1C2222653
Subsystem 2 - Serial number: 6342MSME1C0D3E6DY
Subsystem 3 - Serial number: 6352QSME343015711
Subsystem 4 - Serial number: 6362QSME343024655
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
Component: Lenksдulenmodul 036 0070
Coding: 0000002
VCID: 73E5394E12152586991-8026
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 854 A HW: 1K0 920 854 A
Component: KOMBIINSTRUMENT VN4 3605
Revision: V0010000 Serial number: VWXBZ0G0651781
Coding: 0005103
Shop #: WSC 50741 143 61874
VCID: 29591B2680592F56E3D-807C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 061114F1002090
Coding: 350000
VCID: 7EF3187AE95778EEE6F-802B
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VN4 3605
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 N HW: 3C8 035 279 N
Component: RNS315-EU H73 0407
Serial number: VWZAZ2N0547551
Coding: 0000021102000C0000000000
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3663C05A89E770AE7EF-8063
Data medium:
Subsystem 1 - Part No: 3AA 919 866 A
Component: EUR_E_V4 0049
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120A
Coding: 0000116
VCID: 387FCE624BF386DE6C3-806D
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.068 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3561C7565CE17BB6775-8060
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 18C802487F2D8405484AC6F011CC
Shop #: WSC 00131 935 56600
VCID: 78FF0E620B7346DEAC3-802D
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000116
VCID: 3979CB6670F99FD693D-806C
End ---------------------------------------------------------------------
Zehn
3 Ноя 2008
Второй байт кодировка странная.
04 должно быть если 4 динамика
Третий байт не понимаю, что накодировано.
Посмотри, что в этих байтах выделено галочками и как эти биты подписаны.
Phin
20 Май 2011
VW Caravelle T6 2.0TDI(CAAС)
Попробуй в гейте добавить блок блютуса. Блок не найдет, но может звук проявится. Я так боролся на старой приборке с отображением меню бт
Написал с тапки, за очепятки не пинать.
rekram
19 Сен 2014
спб
гольф 5
задних динамиков у меня нет, поэтомуи поставил 2, но попробую поменять.
3-й байт
Zehn
3 Ноя 2008
Понятно, тогда попробуй проверить может перепутано подключение динамиков перед с задом через меню настройки звука.
rekram
19 Сен 2014
спб
гольф 5
не помогло.
а это меню в самой магнитоле есть?
если включить 4 динамика то он пишет что нет задних, а их действительно нет.
может это железный косяк какой?
еще странность заметил в блоке гетвея в длинном кодировании всего 3 байта и те без подписей, это шнурок у меня старый или с гетвеем беда?
fbear
12 Май 2013
МО, Одинцово
Touareg
помогло? у самого старая приборка, меню БТ так и не появилось пока, блок БТ добавлял - меню появилось, но выдает ошибку при скане :(
http://b6club.ru/viewtopic.php?f=12&p=528823#p528823
rekram
19 Сен 2014
спб
гольф 5
Phin
20 Май 2011
Если мне, то да, помогло, и отчет тут выкладывал. На старой приборке дорестайла появилось меню бт. При скане да, есть ошибка по блоку бт, но на скорость это не влияет и видно только сканом.
fbear
12 Май 2013
МО, Одинцово
Touareg
Спасибо, буду возвращать тогда, а то задолбался по экрану тыкать :(
rekram
19 Сен 2014
спб
гольф 5
Bummg, подключен, но выведен только в бардачек пока. Толку ноль от него без звука((
Bummg
18 Сен 2014
Scirocco 2.0T st.1 Revo
Подключил точно все правильно? Там других вариантов нет. Либо неправильно подключил, либо он неисправен
rekram
19 Сен 2014
спб
гольф 5
Bummg,звука из колонок нет, даже при отключенном/неправильноподключенном микрофоне поидее музыка по блютусу играть должна.
Phin
20 Май 2011
однозначно должна,может РНСка кривая...
Bummg
18 Сен 2014
На счёт музыки спорный вопрос, например, мой тупой китаец Lenovo S850 не воспроизводит музыку через динамики. Хотя в телефоне включена поддержка А2DP. Больше скажу - это дерьмо контакты и списки вызовов на магнитолу не выводит. Надо менять телефон, но 6 айфон пока не вписывается в бюджет, 5s после умершей 5 не хочу.
Phin
20 Май 2011
ХЗ у меня НТС с дроидом 2.2-4.4 все работали
rekram
19 Сен 2014
спб
гольф 5
Bummg,контакты импортировались нормально, iphone пробовал, с него тоже не играет. Во время транспортировки удар был и магнитола нмного мятая, грешу на это...эххх(
maveric79
1 Апр 2014
skoda
А диагностика что выдает?
Похоже, но я бы еще в другое авто будет воткнул, попробовал..
