Вот что смог сделать
Scan: 01 02 03 05 08 09 10 15 16 17 19 1C 22 25 2B 2E 42 44 46 52
53 55 56 62 65 69 72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0010
Address 01: Engine (J623-CLJA) Labels: None
Part No SW: 03L 906 018 LJ HW: 03L 907 309 AD
Component: R4 2,0L EDC H25 2726
Revision: 42H25--- Serial number: 00000000000000
Coding: 001A0012042600080000
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_ECM20TDI01103L906018LJ 003008
ROD: EV_ECM20TDI01103L906018LJ_VW36.rod
VCID: 7DF11F7FEC04B5F6FF5-8028
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 FD HW: 09G 927 750 FD
Component: AQ 250 6F 2187
Revision: 00H97000 Serial number:
Coding: 0000328
VCID: 78FF0E6B0B2690DEAC3-802D
Address 03: ABS Brakes Labels: None
Part No SW: 5N0 614 109 BC HW: 5N0 614 109 BC
Component: J104 C6 450M V457 0011
Revision: --H07--- Serial number: 00000006454013
Coding: 0001604
VCID: 6DD12F3F746425764F5-8038
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0193087223
Coding: 030C0C
ASAM Dataset: EV_KESSYPQ35G A02013
ROD: EV_KESSYPQ35G.rod
VCID: 3467FA5B9FCEB4BE40B-8061
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 GK HW: 5K0 907 044 GK
Component: Climatronic H19 1313
Revision: 00001004
Coding: 0010004002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 7AFB1463FD2A82CEDA7-802F
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 48180A3B8837F3C0448800C0340009644B55AB08577D85F0E4840000A040
Shop #: WSC 00028 123 12345
VCID: 3E73D873A9826EEEA6F-806B
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 201112 03 32 0010
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 241112 05 54 0403
Coding: 02304D
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels: 1Q0-919-475.clb
Part No SW: 5N0 919 475 D HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0045
Revision: -------- Serial number: 32961232503619
Coding: 118102
ASAM Dataset: EV_EPHVA14VW3680000 001005
ROD: EV_EPHVA14VW3680000.rod
VCID: 3A7BD463BDAA42CE9A7-806F
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__20F VW10 HI 2118
Revision: 24017000 Serial number: 003L7PP270PT
Coding: 0012358
VCID: 7CF7127B3F1EBCFEC8B-8029
Subsystem 1 - Serial number: 6332MTS648603102
Subsystem 2 - Serial number: 6342MTS657573152
Subsystem 3 - Serial number: 6351HTS62EV3IBKR
Subsystem 4 - Serial number: 6361HTS6LMNEIBKR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 BL HW: 5K0 953 569 L
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20121130300408
Coding: 1102140000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 75E1075FD434EDB6B75-8020
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Coding: 820000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5N0 920 873 A HW: 5N0 920 873 A
Component: KOMBI H05 0705
Coding: 111F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3169F34F60DC81962BD-8064
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AJ HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1634
Revision: H51 Serial number: 271112F1003971
Coding: 356002
VCID: 78FF0E6BCB2690DEAC3-802D
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RL9W407
Coding: 0000002
VCID: FEF39873A9022EEE66F-80AB
Address 22: AWD Labels: None
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 4D918FBFD424C5762F5-8018
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA4230D8AB24EAA7-80BF
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000252690002
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F6DF53776E897663D9-807A
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663821830
Coding: 010100
VCID: 2A5BE423450AF24EEA7-807F
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 701 G HW: 3C0 959 793 C
Component: TUER-SG FT 002 0503
Revision: 12110009 Serial number: 0006034968
Coding: 0010BE
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 3979CB6FB8AC49D693D-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1504
Serial number: 00000007436135
Coding: 000090
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 P HW: 5N1 909 148 J
Component: J500__APA-BS KL.286 1202
Revision: 1BH04839 Serial number: 00123350346601
Coding: 0000258
VCID: 3F8DA5776E8867E6AD9-806A
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 702 G HW: 3C0 959 792 C
Component: TUER-SG BT 002 0503
Revision: 14110009 Serial number: 0006041432
Coding: 0011BE
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1504
Serial number: 00000007433915
Coding: 000090
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000594437
Coding: 0026157
VCID: 3663C05341B2A6AE7EF-8063
Address 55: Xenon Range (O745) Labels: None
Part No SW: 0M0 907 307 F HW: 2L6 907 307 C
Component: DFS-ECU% H54 0411
Revision: (------( Serial number: (------(------
Coding: 011A00000B000205
Shop #: WSC 01530 935 41160
ASAM Dataset: @V_HeadiRegulVRAFSPt 502016
ROD: N/A
VCID: 2D51EF3F7CE4E5760F5-8078
Subsystem 2 - Part No SW: 1H0 941 379 HW: 1H0 941 379
Component: IeiMo llnks H52 0510
Coding: 140500
No ASAM data for: "@V_HeadiRegulVRAFSPt" (VW36)
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2M4697858
Coding: 0100040004000C
VCID: 3365F94792C0B386591-8066
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000174291
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_SE36.rod
VCID: 3561C75F94B4ADB6775-8060
1 Fault Found:
8402177 - System Switched Off
C106D 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 193
Mileage: 45535 km
Date: 2020.14.27
Time: 09:10:06
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00008030224533
Coding: 410D000101000000
Shop #: WSC 01357 011 00200
VCID: 3169F34F68DC81962BD-8064
1 Fault Found:
03621 - Socket for Trailer Connection
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 87
Mileage: 49852 km
Time Indication: 0
Date: 2023.14.06
Time: 14:42:40
End ---------------------------------------------------------------------
