hel
- Регистрация
- 21 Окт 2014
- Сообщения
- 95
- Благодарности
- 29
- Адрес
- Минск
- Автомобиль
- 2014 Tiguan TDI T&F+ оба техника+комфорт белий-белий
Машина с Keyless. При нажатии на кнопку, на ПБ загорается только красный руль и тормоз, не заводится. Работает магнитола\климат\фары, т.е. АКБ врядли разряжен. Пробовали оба ключа
Вася при диагностике выдает следующее:
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes
Cannot be reached
Address 05:
No fault code found.
Address 08:
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 Q HW: 5K0 937 086 Q
Component: BCM PQ35 M 122 0173
Revision: BC122001
Coding: 4E180A3B8C27F3C0448800C0340009E44BD5AB08776D85B0E4840000A040
Shop #: WSC 01530 935 00200
VCID: 428BAC83DD7A0A0EC27-8017
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 140314 03 32 0010
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 190314 05 54 0403
Coding: 022B4D
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
9 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 50
Reset counter: 44
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:49
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
OFF
OFF
ON
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
00987 - Lamp for Brake Light; Left (M9)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 3
Reset counter: 21
Mileage: 78521 km
Time Indication: 0
Date: 2056.14.24
Time: 11:47:22
Freeze Frame:
Term 15 On
Voltage: 14.40 V
ON
ON
OFF
OFF
ON
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:53
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:53
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags
Cannot be reached
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 DM HW: 5K0 953 569 AP
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140410300081
Coding: 1102140000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 78FF0E6BC32690DEAC3-802D
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Address 17:
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 37
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.03
Time: 20:30:18
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RQ2ZQ07
Coding: 0000002
VCID: FEF39873A9022EEE66F-80AB
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 03:42:13
Address 22: AWD
Cannot be reached
Address 25: Immobilizer (J334)
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 701 G HW: 3C0 959 793 C
Component: TUER-SG FT 002 0503
Revision: 12110009 Serial number: 0008410539
Coding: 0010BE
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 3979CB6FB8AC49D693D-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 F HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1504
Serial number: 00000008696039
Coding: 000090
1 Fault Found:
68107 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Date: 2057.14.04
Time: 03:42:09
Address 44: Steering Assist
Cannot be reached
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 5N0 959 702 G HW: 3C0 959 792 C
Component: TUER-SG BT 002 0503
Revision: 14110009 Serial number: 0008378330
Coding: 0011BE
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 3A7BD463BDAA42CE9A7-806F
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 F HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1504
Serial number: 00000008697176
Coding: 000090
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Date: 2057.14.04
Time: 03:42:09
Address 53: Parking Brake
Cannot be reached
Address 55: Xenon Range
Cannot be reached
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L1589201
Coding: 00000440040400
Shop #: WSC 05314 123 12345
VCID: 2345090722202306A91-8076
1 Fault Found:
00625 - Vehicle Speed Signal
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 03:42:23
Address 65: Tire Pressure
Cannot be reached
Address 01: Engine
Cannot be reached
Cannot be reached
Cannot be reached
Address 05:
Address 08:
Revision: BC122001
Coding: 009795
Coding: 022B4D
Coding: 000000
Coding: 000000
9 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 50
Reset counter: 44
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:49
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 21
Mileage: 78521 km
Time Indication: 0
Date: 2056.14.24
Time: 11:47:22
Freeze Frame:
Term 15 On
Voltage: 14.40 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:53
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:53
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 17:48:55
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
ON
Cannot be reached
Address 15: Airbags
Cannot be reached
Coding: 1102140000
Coding: 820000
Address 17:
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 37
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.03
Time: 20:30:18
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 03:42:13
Address 22: AWD
Cannot be reached
Coding: 0010BE
Slave Driver:
Coding: 000090
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Date: 2057.14.04
Time: 03:42:09
Cannot be reached
Coding: 0011BE
Slave Passenger:
Coding: 000090
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Date: 2057.14.04
Time: 03:42:09
Cannot be reached
Cannot be reached
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 4
Mileage: 79451 km
Time Indication: 0
Date: 2057.14.04
Time: 03:42:23
Cannot be reached
