отправлял почтой россии (заказным),
дома посмотрю обратник который пришёл или тут на работе в компе должно быть сейчас посмотрю
[FONT="]Прожив 10 лет в России, он [/FONT]
[FONT="]так и не смог понять, почему [/FONT]
[FONT="]ху..во – это плохо, а пи..дато – это[/FONT]
[FONT="]хорошо. Но главное, почему[/FONT]
[FONT="]пи..дец – это хуже, чем ху..во, [/FONT]
[FONT="]а оху..нно – это лучше, [/FONT]
[FONT="]чем пи..дато.[/FONT]
Prof. Dr. Dr. h.c. mult. Martin Winterkorn
Wolfsburg Office
Volkswagen
VHH 11. floor
P.O. Box 1849
D-38436 Wolfsburg
Germany
Добавлено через 4 минуты
[FONT="]I ............Alexander, address 396...., st. ............ лолд / 6 , ........ Voronezh region. RF., since 26.02.2011 own a car of VW Tiguan 1,4 150hp VIN № 00000000000.[/FONT]Operation was carried out in accordance with the manufacturer's recommendations. Maintenance was carried out in a timely manner at the recommended dealer Volkswagen Company "Autolux" Belgorod, as confirmed in service book.
By purchasing a product VAG, I was expecting to get a quality and reliable car from company, which has established itself in the market with the best hand. During operation of the vehicle, the following happened:
10/08/2011, with the passage of Technical Service 29 648.00 km mileage I stated to the master-inspector of background noise, increasingly appears when you start the engine.
This defect wasnt corrected.
10/30/2011, I was invited to the service to correct the defect causing the specified noise. Vehicle mileage is 31 645 km. In costume - order issued after the work, it said that the regulator valve timing was replaced. (Please note that this replacement causes other work. Eliminating the defect is described in an article of «AutoBild» magazine№ 11 (49) / 2012. Which states that the cause of the defect is the timing chain tension).
29/04/2012, with the mileage of 38,678 km. I had to re-apply to the service, because of the oil passes from the front of the engine near the crankshaft.
Master from service indicated that since 11.03.2012g the cars two year warranty is over, and therefore the repair will be at my expense. I insisted that the oil leak is the result of the previous warranty replacement of phase adjuster. Service conceded and offered to repair the defect in accordance with "KULANZ" for which I choose to pay of either a work for replacement or the necessary components. I paid for the work, after which the repair was completed.
07.07.2012g. with mileage of 44 639 km. vehicle serviced Technical Servise 3 held regularly.
[FONT="]17.11.2012with mileage of 53 626 km. the engine of my car started to work irregularly and triggered light signal «Check Engine» on the control panel. In accordance with the recommendations Tiguana manual (page 305), I turned to the service. Service workers verbally reported that they had a computerized engine diagnostics, followed by measuring the compression in the cylinders, and found that in the second cylinder compression is [/FONT]
Добавлено через 36 секунд
different from the others and is 7.1 kg/cm2, and the further establishment of failure is possible only after the removal of the engine.
26.11.2012g. master service contacted me by phone and said that the engine defect - burnout of two exhaust valves of gas distribution mechanism of the second cylinder. Also i was informed verbally that the cost of removing the defect with parts(details) and service work will be 55 000 rubles. But this price is not final and will be updated after the repair. Please focus attention on the fact that other defects havent been reported to me.
Nor any written document confirming the defect and rates its elimination I was given.
After that I went to the LLC "FolksvagenGrupRus" as a hotline and in writing, by e-mail, as well as by fax with a request to remove this defect free or according to«KULANZ». In response, members of LLC "FolksvagenGrupRus" told me that I have to resolve the issue with "Autolux" Belgorod.
Employees of "Autolux" Belgorod in the letter number 208 of 10.01.2013 refused to conduct free repair. In repair service «Kulanz» they also refused and demanded to remove my car from the territory of the service.
12.01.2013, I arrived in OOO "Autolux" which found that the engine of my car is complete. Written confirmation of defects and rates of work I did not provide. On my request to explain the detected defects and their causes, the master offered me to show them clearly. In the repair area I was shown lying on the repair desk two piston assemblies with rods. They said that these pistons are removed from the engine of my car. In this case, explained that the entire data components and do not have any defects. Then showed two exhaust valves, which lies near the cylinder head. The two exhaust valves did not have any defects (burnouts, cracks, work hardening or non-perpendicular to the stem plate at the place fit the valve seat). Working rims were identical in width and color on the surface. At the transition from the plate onto the valve stem on the radius, had no foreign deposits. Exhaust chamber, valve guides and valve seats in the cylinder head had no visible defects. My request to show burnout valve master did not satisfied. And he asked to leave the repair zone. After the release of the repair zone master said that the car for repairs needs to make 50% payment of the cost of repairs. This payment will confirm my consent to engine repair and service use up the funds for the purchase of spare parts for repair. For another my request to describe, in writing, defects and cost calculation, master service said that the documents are not ready.
After that, I have repeatedly contacted the staff of LLC "Autolux" to provide me the documents confirming the defect of my car and prices for its repair.
25.01.2013 year, I sent a registered letter to the service - a claim, and it asks you to specify the term of issue of documents confirming the defect and cost of the work for its removal.
01.02.2013, with service centers by fax sent two documents:
- Repair list, in which as a defect was indicated burnout intake valves. The cost of parts covered by this statement is 23 370 rubles. ;
- Calculation of the cost of a 25 480 rub ..
I asked for clarification of the defect (originally - burnout exhaust valves)
07.02.2013 from service center of LLC "Autolux" by fax, addressed to me received documents that have an inventory of documents that he was given a reference number and the date of the following applications:
- Repair list from 01.02.2013, the, where the defect is specified burnout exhaust valves. Cost of spare parts under the new statement was 23,445 rubles.;
- Purchase order from 06.02.2013 cost of repair work on 25 480 rub.; In documents are indicated services (workings)not related with the claimed defect, such as the removal of the crankcase, removing piston groups. This work is regarded and presented for payment, although I drew earlier on my other defects havent been reported.
Total time spent in the service vehicle to detect defects and costing repairs to the provision of documents in my case was 89 days.
Conclusions:
Defect, burnout valves, was not confirmed by the service.
This defect could not occur in the engine Volkswagen for 2 years and 8 months.
I followed all the recommendations for use of the vehicle and provided a car to conduct maintenance on time.
Maintenance be performed at the recommended dealer Volkswagen Company "Autolux" Belgorod.
No signs of improper operation or maintenance of the car.
This defect could not be my fault.
I suggest you make the right decision and make a 100% free car repair VW Tiguan WIN № 000000000000 VW's expense within a reasonable time set by the current standards of VW.
Please do not forward the claim to the Company "FolksvagenGrupRus" since I spoke to them many times, but no any solution to my problem on their part did not follow. As a result of inactivity and the transfer of responsibility to the Company "Autolux" I can not use your product from 17.11.2012 year.
About the decision to ask you to give me a reasonable time a written response to the address 396000, st. нннннн 99а / 2, рарапрар region. RF.
Regards
Alexander .
ВОТ ЭТОТ ТЕКСТ И ОТПРАВЛЯЛ В ГЕРМАНИЮ.
УДАЧИ!!!!!!!!!!!!!!!!!!!!!!
найду ответ сейчас и тоже выложу на обозрение всем участникам и желающим
