помогите плиз с ошибками
сделал диагностику vag com, показал следующие ошибки
из видимого то, что не работает система адаптивного освещения, соответствующую ошибку выдаёт приборка...
Sunday,26,July,2015,15:37:06:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: XW8ZZZ5NZDG128077 License Plate:
Chassis Type: 5N (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 25 2B 2E 37 42 44 46 52
53 55 56 62 65 72
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 GK HW: 5K0 907 044 GK
Component: Climatronic H19 1313
Revision: 00001004
Coding: 0010004002
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 7AFB1463FD2A82CEDA7-802F
1 Fault Found:
9472881 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [008] - Actuator stuck
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 57794 km
Date: 2026.14.05
Time: 11:07:06
Address 15: Airbags
Cannot be reached
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H08 5218
Revision: AB001001 Serial number: VWZ6Z7N6256298
Coding: 04000400040000800000
Shop #: WSC 12345 123 12345
VCID: 3B75D167BA907BC6811-806E
Subsystem 1 - Part No: 1T0 919 859 C
Component: EU East V9 7894
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 56098 km
Time Indication: 0
Date: 2025.14.25
Time: 18:42:36
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000787249
Coding: 0026157
VCID: 3663C05341B2A6AE7EF-8063
1 Fault Found:
01321 - Control Module for Airbags (J234)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Mileage: 59248 km
Time Indication: 0
Date: 2026.14.11
Time: 14:33:54
Freeze Frame:
Voltage: 11.90 V
Count: 161
Speed: 0.0 km/h
Hex Value: 0x1263
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Xenon Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 041A00000B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: 377DCD578EB85FA6659-8062
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329
Component: LeiMo links H02 0010
Coding: 860000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329
Component: LeiMo rechts H02 0010
Coding: 860000
3 Faults Found:
13636608 - Control Module Incorrectly Coded
U1014 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 6
Mileage: 59248 km
Date: 2026.14.10
Time: 23:14:58
5276145 - Power Output Module for Left Headlamp
C1081 F1 [137] - Incorrectly Coded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 59248 km
Date: 2026.14.10
Time: 23:14:58
5276401 - Power Output Module for Right Headlamp
C1082 F1 [137] - Incorrectly Coded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 6
Mileage: 59248 km
Date: 2026.14.10
Time: 23:14:58
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 46
Mileage: 56098 km
Time Indication: 0
Date: 2025.14.25
Time: 18:42:36
