всем привет.
сегодня просто так полез проверить ошибки шнурком и вот это словил:
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 MK HW: 09G 927 750 MK
Component: AQ 250 6F 2186
Revision: 00H97000 Serial number:
Coding: 0000328
Shop #: WSC 01530 935 00200
VCID: 86056043F1A57F2E2EF-80D3
1 Fault Found:
16997 - Transmission Control Module
P0613 - 004 - Processor Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 38393 km
Time Indication: 0
Date: 2023.14.27
Time: 00:03:45
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0068
Revision: BC021001
Coding: 48180A3BEC37F3C0408800C036000DEC4B55AB08777D8DF0E4840800A040
VCID: 3E7548A3A9F567EEA6F-806B
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 230113 03 32 0010
Coding: 009F95
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 300113 05 54 0403
Coding: 07104D
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
3 Faults Found:
00924 - Relay for Headlamp Cleaning System (J39)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 119
Mileage: 39467 km
Time Indication: 0
Date: 2025.14.10
Time: 21:54:19
Freeze Frame:
Term 15 Off
Voltage: 12.55 V
OFF
ON
OFF
OFF
OFF
01259 - Fuel Pump Relay (J17)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 217
Mileage: 38393 km
Time Indication: 0
Date: 2023.14.27
Time: 00:00:04
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 5
Fault Frequency: 123
Reset counter: 155
Mileage: 38447 km
Time Indication: 0
Date: 2023.14.29
Time: 17:59:06
Freeze Frame:
Term 15 Off
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
постирал эти ошибки, проехал пару км по городу, заново проверил - все чисто.
что бы это могло быть? куда копать? или ложная тревога?
