wikw
появились ошибки
подкажите плиз
Address 03: ABS Brakes Labels: None
Part No SW: 5N0 614 109 BJ HW: 5N0 614 109 AM
Component: J104 C6 450M V40E 0023
Revision: --H07--- Serial number: 00000006272302
Coding: 0001562
Shop #: WSC 00070 000 1048576
VCID: 74E73A5B174EF4BE80B-8021
1 Fault Found:
00576 - Terminal 15
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 19
Mileage: 104601 km
Time Indication: 0
Date: 2017.14.19
Time: 13:04:16
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.25 V
Bin. Bits: 00111110
Count: 128
Hex Value: 0x0000
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 N HW: 5N1 909 148 G
Component: J500__APA-BS KL.333 1401
Revision: 1AH03837 Serial number: 00122690398201
Coding: 0000258
Shop #: WSC 01530 935 00200
VCID: 3D71DF7F648475F6BF5-8068
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 19
Mileage: 104601 km
Time Indication: 0
Date: 2017.14.19
Time: 13:04:16
Freeze Frame:
Term 15 Off
RPM: 0 /min
Speed: 0.0 km/h
(no units): 11.0
Voltage: 12.30 V
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 10000000161170
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_SE36.rod
VCID: 3561C75F94B4ADB6775-8060
2 Faults Found:
12656647 - No Communication with ABS Brake Control Module
U0121 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 104601 km
Date: 2081.14.19
Time: 13:04:13
12656671 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 104601 km
Date: 2081.14.19
Time: 13:04:13
понятно что абс - или контроль давления в шинах - а конкретно что - непонятно
плиизз
подкажите плиз
Coding: 0001562
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 19
Mileage: 104601 km
Time Indication: 0
Date: 2017.14.19
Time: 13:04:16
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 12.25 V
Bin. Bits: 00111110
Count: 128
Hex Value: 0x0000
Coding: 0000258
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 19
Mileage: 104601 km
Time Indication: 0
Date: 2017.14.19
Time: 13:04:16
Freeze Frame:
Term 15 Off
RPM: 0 /min
Speed: 0.0 km/h
(no units): 11.0
Voltage: 12.30 V
2 Faults Found:
U0121 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 104601 km
Date: 2081.14.19
Time: 13:04:13
U0146 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 19
Mileage: 104601 km
Date: 2081.14.19
Time: 13:04:13
плиизз
