[15:19:30][JC:check_model_info:1374]app_version:[1.005]
[15:19:30][JC:check_model_info:1378]app_model:[500GW]
[15:19:30][JC:check_model_info:1382]app_language:[Russian]
[15:19:30][JC:check_model_info:1389]cli_version:[2.032]
[15:19:30][JC:check_model_info:1393]cli_model:[500GW]
[15:19:30][JC:check_model_info:1397]cli_language:[Russian]
[15:19:30][JC:check_model_info:1404]cfg_version:[1.030]
[15:19:30][JC:check_model_info:1408]cfg_model:[500GW]
[15:19:30][JC:check_model_info:1412]/mnt/mmc/BlackVue/Config/version.bin read End
[15:19:30]#####[check_version:1441]firmware_version:1.005, FIRMWARE_VERSION:1.005
[15:19:30][check_version:1458] config.ini is 1.030...
[15:19:31][JC
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ta_parameter_init:3404] overwrite set >>>> (time)
[15:19:34]Start_System
[15:19:34][audio_play:2503] Audio Play thread count:1
[15:19:34][audio_play:2509] Audio Play thread count:1
[15:19:34][motion_init:101]Record Parking
[15:19:37][audio_play:2503] Audio Play thread count:2
[15:19:37][audio_play:2509] Audio Play thread count:2
[15:19:43]GPS Start
[15:19:44][recfile_start:727] OPEN FILE 20130602_151943_N
[15:20:45][pta_close:3559]REC FILE CLOSE
[15:20:45][recfile_start:727] OPEN FILE 20130602_152044_N
[15:21:46][pta_close:3559]REC FILE CLOSE
[15:21:46][recfile_start:727] OPEN FILE 20130602_152145_N
[15:22:47][pta_close:3559]REC FILE CLOSE
[15:22:47][recfile_start:727] OPEN FILE 20130602_152246_N
[15:23:48][pta_close:3559]REC FILE CLOSE
[15:23:48][recfile_start:727] OPEN FILE 20130602_152347_N
[15:24:49][pta_close:3559]REC FILE CLOSE
[15:24:49][recfile_start:727] OPEN FILE 20130602_152448_N
[15:25:50][pta_close:3559]REC FILE CLOSE
[15:25:50][recfile_start:727] OPEN FILE 20130602_152549_N
[15:26:50][pta_close:3559]REC FILE CLOSE
[15:26:51][recfile_start:727] OPEN FILE 20130602_152650_N
[15:27:52][pta_close:3559]REC FILE CLOSE
[15:27:52][recfile_start:727] OPEN FILE 20130602_152751_N
[15:28:52][pta_close:3559]REC FILE CLOSE
[15:28:52][recfile_start:727] OPEN FILE 20130602_152852_N
[15:29:53][pta_close:3559]REC FILE CLOSE
[15:29:53][recfile_start:727] OPEN FILE 20130602_152952_N
[15:30:54][pta_close:3559]REC FILE CLOSE
[15:30:54][recfile_start:727] OPEN FILE 20130602_153053_N
[15:31:55][pta_close:3559]REC FILE CLOSE
[15:31:55][recfile_start:727] OPEN FILE 20130602_153154_N
[15:32:56][pta_close:3559]REC FILE CLOSE
[15:32:56][recfile_start:727] OPEN FILE 20130602_153255_N
[15:33:57][pta_close:3559]REC FILE CLOSE
[15:33:57][recfile_start:727] OPEN FILE 20130602_153356_N
[15:34:58][pta_close:3559]REC FILE CLOSE
[15:34:58][recfile_start:727] OPEN FILE 20130602_153457_N
[15:35:59][pta_close:3559]REC FILE CLOSE
[15:35:59][recfile_start:727] OPEN FILE 20130602_153558_N
[15:37:00][pta_close:3559]REC FILE CLOSE
[15:37:00][recfile_start:727] OPEN FILE 20130602_153659_N
[16:34:19][JC:check_model_info:1374]app_version:[1.005]
[16:34:19][JC:check_model_info:1378]app_model:[500GW]
[16:34:19][JC:check_model_info:1382]app_language:[Russian]
[16:34:19][JC:check_model_info:1389]cli_version:[2.032]
[16:34:19][JC:check_model_info:1393]cli_model:[500GW]
[16:34:19][JC:check_model_info:1397]cli_language:[Russian]
[16:34:19][JC:check_model_info:1404]cfg_version:[1.030]
[16:34:19][JC:check_model_info:1408]cfg_model:[500GW]
[16:34:19][JC:check_model_info:1412]/mnt/mmc/BlackVue/Config/version.bin read End
[16:34:19]#####[check_version:1441]firmware_version:1.005, FIRMWARE_VERSION:1.005
[16:34:19][check_version:1458] config.ini is 1.030...
[16:34:19][JC
[16:34:22]Start_System
[16:34:23][audio_play:2503] Audio Play thread count:1
[16:34:23][audio_play:2509] Audio Play thread count:1
[16:34:23][motion_init:101]Record Parking
[16:34:26][audio_play:2503] Audio Play thread count:2
[16:34:26][audio_play:2509] Audio Play thread count:2
[16:34:32]GPS Start
[16:34:32][recfile_start:727] OPEN FILE 20130602_163432_N
[16:34:33]Power OFF
[16:34:33][pta_main:1738]OUT3-0[REC END PROC1:0]
[16:34:33]Serial end.
[16:34:33][pta_close:3559]REC FILE CLOSE
[16:34:33][pta_main:1751]OUT3-0[REC END PROC2]
[16:34:34]End System - 1
[16:34:34]End System umount
