Владимир и 33 регион
Denis_ka
31 Мар 2009
56.129042,40.40703
Володь, ошибки выложу сюда под спойлер
Address 01: Engine (CAW) Labels: 06J-906-026-CAW.clb
Part No SW: 06J 906 026 AB HW: 06J 906 026 D
Component: MED17.5 4304
Revision: A7H20--- Serial number:
Coding: 04230003190F0160
Shop #: WSC 13872 284 403014
VCID: 6ADFC69B3EBF
2 Faults Found:
000772 - Cylinder 4: Misfire Detected
P0304 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 42930 km
Time Indication: 0
Date: 2096.14.30
Time: 08:01:41
Freeze Frame:
RPM: 870 /min
Load: 35.7 %
Speed: 0.0 km/h
Temperature: 7.0∞C
Temperature: -3.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
000770 - Cylinder 2: Misfire Detected
P0302 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 42930 km
Time Indication: 0
Date: 2096.14.30
Time: 08:01:41
Freeze Frame:
RPM: 870 /min
Load: 35.7 %
Speed: 0.0 km/h
Temperature: 7.0∞C
Temperature: -3.0∞C
Voltage: 14.224 V
Readiness: 0000 0000
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 AT HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20120218200376
Coding: 198A140000
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS_VW36.rod
VCID: 7CF3F0C3442B
MFL:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 820000
1 Fault Found:
147462 - Terminal 15
B1148 12 [008] - Algorithm Failure
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Reset counter: 99
Mileage: 30772 km
Date: 2024.14.31
Time: 11:26:20
Address 22: AWD Labels: None
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 4D956D07AF11
1 Fault Found:
02248 - Valve for Controlling Clutch Operating Angle (N373)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 40
Mileage: 43113 km
Time Indication: 0
Date: 2097.14.09
Time: 10:50:32
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 J HW: 1T0 035 680 J
Component: RNS-MID H61 3970
Revision: AB001001 Serial number: VWZ6Z7M2033075
Coding: 0400040204000080000C
ASAM Dataset: ------------------------- ------
VCID: 356525E72781
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 115
Reset counter: 58
Mileage: 36175 km
Time Indication: 0
Date: 2026.14.14
Time: 20:45:02
Address 4C: Tire Pressure II
Cannot be reached
Address 56: Radio Labels: 1T0-035-680.clb
Component: RNS-MID H61 RNS-MID H61 39703970
VCID: 356525E72781
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End ---------------------------------------------------------------------
удалил безошибочные блоки
Rom972
15 Янв 2012
Ковров
А сейчас какой пробег у Володи?
Denis_ka
31 Мар 2009
56.129042,40.40703
Rom972, что то я в логе этого не вижу, если склероз не подводит, то 43 с чем то тыс.
Володь, почитай отсюда
Barmaleykin
17 Июл 2011
г. Владимир
Тигуанчик
43500 км
Разобрал задок, а там полная фиготень, все весит, все соединения в колодку не запиханы а обмотаны клейким паралоном. Но все чистенько сухо, теперь даже не знаю что и думать
oleg3110_78
29 Июл 2008
Город на болоте
ТД 2017, НЛ на вишне
Для начала прозвони кабель до рнс (по идее синие разъёмы). Хорошо бы найти кого-то с антенной установленной на аппарате. Плавник без снятия не разобрать
Barmaleykin
17 Июл 2011
г. Владимир
Тигуанчик
Рома, сейчас посмотрел фотку по твоей ссылке http://www.tiguan-club.org/topic/442-%D1%84%D0%BE%D1%82%D0%BE%D0%BE%D1%82%D1%87%D0%B5%D1%82-%D0%BF%D0%BB%D0%B0%D0%B2%D0%BD%D0%B8%D0%BA-%D1%81-%D0%B0%D0%BD%D1%82%D0%B5%D0%BD%D0%B0%D0%BC%D0%B8-%D0%BD%D0%B0-%D0%BA%D1%80%D1%8B%D1%88%D1%83/?p=3292 и обнаружил, что я видел только один провод входящий в плавник из нутри. Кто-нибудь может сказать найдя куда уходят как минимум еще два конца, их можно будет вставить в плавник? Или плавник под замену? И кто нибудь имеет фотку ЖПСного плавника, он с проводами или без?
oleg3110_78
29 Июл 2008
Город на болоте
Если у тебя рестайл с навигацией без вебасто и подготовки телефона, то у тебя в плавнике только ГПС антенна и соответственно один провод с одним разъемом синего цвета. Остальные провода на моих фото выходящие из плавника к ГПС отношения не имеют и использовать их для ГПС нельзя. Сколько бы систем не было в плавнике у ГПС антенны разъемы ТОЛЬКО синего цвета.
Пы.Сы. кстати фотки обоих вариантов плавников в той теме есть, в первом сообщении дристайл с радиоштырем ниже рестайл без штыря
Denis_ka
31 Мар 2009
56.129042,40.40703
Володь, как дела с навигацией твоего авто?
attachment.php
Мож какие клипсы заказать? ;)
Barmaleykin
17 Июл 2011
г. Владимир
Тигуанчик
attachment.php
Не фурычит! Подумываю отложить сие мероприятие на конец марта или начало апреля
Возможно нужно найти ДРИФТКИНГа, раньше был в Ивановской ветке электрик дилерский, делал много вещей по внедрению в свой авто, наверняка подскажет чего-нибудь, это как раз по его части
Barmaleykin
17 Июл 2011
г. Владимир
Тигуанчик
Рома, не помнишь номерок нашего моторного масла (Плюс) на 1 литровую канистрочку?
Denis_ka
31 Мар 2009
56.129042,40.40703
Denis_ka
31 Мар 2009
56.129042,40.40703
сейчас ниже почти 800р не вижу, только если пентосин)
Barmaleykin
17 Июл 2011
г. Владимир
Тигуанчик
я хоть и не Рома, но
G052167M2
Ден, я просто не хотел тебя напрягать номерками, но "на ловца и зверь бежит". Ден закажи мне один литровый флакончик вот этого которого написал.....
Denis_ka
31 Мар 2009
56.129042,40.40703
Barmaleykin
17 Июл 2011
г. Владимир
Тигуанчик
Rom972, Рома у нас с тобой подкатывает срок замены тормозухи и масла в Haldex, ты будешь менять, ото мне одному скучно...:az:
Rom972
15 Янв 2012
Ковров
Володь, моему три годика в конце мая исполняется, так что пока терпит. А ты когда собираешься?
