RNS 315 вопрос-ответ
rekram
19 Сен 2014
спб
гольф 5
maveric79, диагностика все ок говорит
hassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 GG
Component: SIMOS71 1.6l 2V 1025
Revision: --H04--- Serial number: VWXBZ0G0651781
Coding: 0004071
Shop #: WSC 01279 785 00200
VCID: 6ADB242A45DFE44E2A7-803F
No fault code found.
Readiness: 0010 1101
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8DA57E6EDDB1E6AD9-806A
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 79F90B6630795FD6D3D-802C
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007320642
Coding: 118F8F27000F1500471400001400000000097F073200010C000000000000
Shop #: WSC 01287 785 00200
VCID: 71E93346680917966BD-8024
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 030707 021 0501
Coding: 00040853
Shop #: WSC 01287
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 39 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1BHUWB
Coding: 0013113
Shop #: WSC 01269 785 00200
VCID: 3D71DF7664D1A3F6BF5-8068
Subsystem 1 - Serial number: 6332MSME1C2222653
Subsystem 2 - Serial number: 6342MSME1C0D3E6DY
Subsystem 3 - Serial number: 6352QSME343015711
Subsystem 4 - Serial number: 6362QSME343024655
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
Component: Lenksдulenmodul 036 0070
Coding: 0000002
VCID: 73E5394E12152586991-8026
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 854 A HW: 1K0 920 854 A
Component: KOMBIINSTRUMENT VN4 3605
Revision: V0010000 Serial number: VWXBZ0G0651781
Coding: 0005103
Shop #: WSC 50741 143 61874
VCID: 29591B2680592F56E3D-807C
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 AP HW: 7N0 907 530 AK
Component: J533 Gateway H57 1653
Revision: H57 Serial number: 061114F1002090
Coding: 350000
VCID: 7EF3187AE95778EEE6F-802B
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VN4 3605
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 N HW: 3C8 035 279 N
Component: RNS315-EU H73 0407
Serial number: VWZAZ2N0547551
Coding: 0000021102000C0000000000
Shop #: WSC 01530 935 00200
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3663C05A89E770AE7EF-8063
Data medium:
Subsystem 1 - Part No: 3AA 919 866 A
Component: EUR_E_V4 0049
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120A
Coding: 0000116
VCID: 387FCE624BF386DE6C3-806D
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.068 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3561C7565CE17BB6775-8060
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 18C802487F2D8405484AC6F011CC
Shop #: WSC 00131 935 56600
VCID: 78FF0E620B7346DEAC3-802D
Subsystem 1 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000116
VCID: 3979CB6670F99FD693D-806C
End ---------------------------------------------------------------------
rekram
19 Сен 2014
спб
гольф 5
ездил сегодня к мастеру который занимается прописывание/ремонтом рнсок сказал в жизни с таким не сталкивался:confused: тоже посоветовал разобрать, может при ударе шлейф какой вывалился. буду ждать тепла или искать теплый гараж:mad:
Zehn
3 Ноя 2008
Навигашка БУ или новая?
Попробовать сделать сброс в заводские настройки.
В адаптациях поковыряться, может чего странное будет накручено
rekram
19 Сен 2014
спб
гольф 5
Zehn, бу, да еще и мятая. сброс делал не помог. адаптации сегодня смотрели, ничего глаз не привлекло.
Customs_UA
19 Янв 2015
Luts'k
VW Caddy 1.6TDI
Добрый день!
У меня вопрос: стоит в машине РНС 315 или 310 ?
Вот даные магнитолы:
- Part number 3C0035279
- Software version 0010
- System hardware version H05
-Navigation data bases EU West 01.
Приехала с Германии: под передним пассажирским сиденьем походу блок БТ.
Можно ее хотя русифицировать или нет(хотя бортовой на русском языке)?
Блутуз и голосовое управление не активировано.
Спасибо огромное!
Rufast
5 Май 2012
Москва, ВАО, САО, Яхрома
Добрый день!
Спасибо огромное!
Насколько мне известно в РНС 315 БТ встроен, а в 310-й нет. Внешне они ничем не отличаются.
Если в машине стоит отдельный блок под сиденьем, можно предположить, что это РНС 310
master7
Партнёр клуба
16 Апр 2008
звоните 89637504619
Добрый день!
Спасибо огромное!
У Вас RNS315 нерусская
Это плохо (по поводу наших карт и русификации)
Customs_UA
19 Янв 2015
Luts'k
VW Caddy 1.6TDI
Походу буду с анг.языком..Попробую активировать БТ и голосовое управление..Предлагают в Киеве русифицировать голову за 50енотов.
Еще раз всем огромное за ответы.:az:
Den_of_Evil
18 Дек 2014
Днепропетровск
Не совсем так. Если заказывалась опция Premium UHV bluetooth, то в RNS315 блютуз деактивирован и стоит дополнительный модуль под сиденьем.
Ufa_
4 Дек 2014
уфа
Парни, у всех ли рнс-315 есть видео выход? а то купил из другого региона, она едет еще, думаю брать камеру или уже дождаться пока приедт...
golf62
30 Окт 2011
Soda Yeti 1.4 outdoor
Заодно и микрофон ищите, блютус встроенный.
Дима_89
21 Ноя 2011
ЯНАО
T&F 2.0 TSI 2014
yurasha61
31 Авг 2012
Липецк
тогда уж про видеовход надо спрашивать
Вот,вот. Видеовыход это для дополнительного монитора, как правило только на "китайцах", на оригинальных мафонах его нет.
yurasha61
31 Авг 2012
Липецк
Камеру нужно брать с проводкой под 26ти контактный разъём.
  • 315 5-разъем.pdf
    77.5 KB · Просмотры: 49
Ufa_
4 Дек 2014
уфа
оу, ну да, видеовход, перепутал) спасибо за инфу)))
Customs_UA
19 Янв 2015
Luts'k
VW Caddy 1.6TDI
Здраствуйте,уважаемые форумчане!
У меня вопрос:на станции активировали блутуз (37 блок/навигация), подключили голосовое управление (правда микрофон еще не подключен)..На станции телефоном через БТ подключился к машине (значек руль и авто) название Nokia CK-7W...После как не пробовал больше не удаеться подключиться/телефон не может найти машину..Что делаю не правильно, поправте?(ключ в замке зажигания,машина не заводится, помню что блутуз должен сам активироваться на 5 минут когда ключ вставлен в замок зажигания)
Спасибо все за ответ!
yurasha61
31 Авг 2012
Липецк
Нажми кнопку телефон, потом настройки, потом сопрягаемые устройства, там должна быть твоя Нокиа, нажми на неё и сделай сопряжение. Если Нокии нет, то нужно снова сделать поиск устройств.
rekram
19 Сен 2014
спб
гольф 5
Customs_UA, а на заведенном двигателе работает?
