найдите в настройках пункт PDC и поставьте на High, вроде так, у меня уже не рцд, плохо помню. в инструкции описано точно)
> в музыку тыкать мальцем? или меню экрана между спид. и тах.?
тогда это через вагком не включить
> Это не то? Да и еще где то встречал что можно это сделать.
Enabling Coming Home/Leaving Home (CH/LH) on NA SE models, thanks RJB!!
The first step is to enable the convenience menu--see above.
Now, there are five places to verify in module 9 (central electronics). Use the long coding helper.
1. Byte 00/bit 5: assistance driving light & leaving home active--set this bit to 1 for active
2. Byte 00/bit 7: coming home active--set this bit to 1 for active
3. Byte 02/bit 4: coming home mode via--set this bit to 0 for personalization
4. Byte 21/bit 6: leaving home variant--set this bit to 0 for LH in LDS
5. Byte 23/bit 5: coming home logic--set this bit to 1 for new logic.
Once these coding changes are made, go into the convenience menu and select the lighting sub-menu. Here you will find coming home and leaving home settings. Select each and set the time in seconds (10 sec intervals) that you want the lights to remain on. Once these changes are made, the functionality for a 2009 NA Tiguan SE with two-position light switch in the off position (factory switch--no need to change) is as follows. Unlock the vehicle with the remote--the lights will come on and remain on for the duration chosen in the convenience menu or until the vehicle is started. Upon arriving, turn off the ignition and if it is dark, turn off the headlamps. Remove the key from the ignition and give a quick pull to the lamp stalk--the high beams will flash. Upon opening the door, the exterior lights will come on. Lock the car with the remote and the lights will remain on for the duration selected in the convenience menu.
это неуверен что можно настроить. нигде в инете не встречал чтоб такое настраивалось
> Это?
http://www.passat-club.ru/forum/showthread.php?t=16999
